Think I found my major traction problem.
Decided to check my pinion angle for the first time ever. I can't believe I haven't looked in to getting suspension work for the rear until now. I guess with the truck being lowered 4" in the back and over 550 passes at the drag strip the leaf springs have been through hell. My pinion angle is at +5 just sitting in the driveway. I'd imagine that goes to +10 whenever I lay into it. Could be the cause of the slight vibration I feel around 90mph at wot. I'll be ordering caltrac bars very soon and also need to shim my rearend to about -5 I guess. Feel free to put in your .02
Where do you get the rearend shims from?
you also dont want your rear end sitting at a perfect 0 unless your in a 4 linked drag car. you want it around -2 through -5* of pinion angle. i have some custom -7* shims around here somewhere that i could sell if i can find them. that should set you right back into the -2* range of pinion angle if your measurements are correct....and in theory haha.
once you figure out what angle you need, do yourself a favor and look up JKW Offroad to get you some good shims. They make all steel shims of any angle that actually bolt to the spring pack. I've used them on several projects.
My truck was not on a level driveway when I measured. I took that into consideration. I checked the angle on driveshaft and rearend and subtracted the difference. Maybe that's not right... hmm. Is it? I'll recheck it on level driveway to be sure.
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
DrX
Sep 29, 2015 04:31 AM
