Th350???
Old Apr 27, 2011 | 09:13 PM
JoeyGC5's Avatar
You've got three options, I've only used one.
1.) Use the front wheel sensor as your vss reference, I've used this and it worked fine, only no more abs
2.) Dakota digital makes a pulse generator that mech connects to the th350 speedo gear and then wires to the vehicle vss input.
3.) Spend the $$$ on a new tailshaft housing
Old Apr 27, 2011 | 10:12 PM
bigboy576103's Avatar
Well at the stage that my trucks in anyways I could give 2 ***** less on having abs haha. Do I have to remove any abs modules or anything after this. ?
Next do u have a link to option number 2 for the sensor conversion oFf tha tranny
Old Apr 28, 2011 | 11:23 AM
00buckshot's Avatar
I think I'm going to keep my ABS and just order the tailhousing from rossler. It might look factory
Old Apr 28, 2011 | 09:00 PM
JoeyGC5's Avatar
cut/connect the wires for one of the front wheel speed sensors, then connect them to the two wires for the trans speed sensor. You can't leave the front speed sensor connected to its original pcm connections. Then you'll have to go into the speedometer tables and play with the pulse counts until the speedometer is accurately displayed.
Old Apr 28, 2011 | 09:03 PM
KozzyJr's Avatar
from what i was told the 4l80e is a th400 but with OD
Old Apr 28, 2011 | 09:17 PM
Yes n no i dont know the whole details but they are similar such as in my 400 im using a 4l80 hub unit for internals since its a bit better due to design. but im no tranny expert jus know what my builder n i discussed so far...
[/QUOTE]
cut/connect the wires for one of the front wheel speed sensors, then connect them to the two wires for the trans speed sensor. You can't leave the front speed sensor connected to its original pcm connections. Then you'll have to go into the speedometer tables and play with the pulse counts until the speedometer is accurately displayed. [/QUOTE]
everything is still up in the air for me but using that sensor how would i dissable the abs completely in the computers..
Old Apr 30, 2011 | 10:37 AM
JoeyGC5's Avatar
By disabling the input, the ABS is defaulted into "stupid/wait" mode and is thereby nonoperational. Once the front sensor is reconnected to the computer, then abs will resume operation.
jshouse
Sep 12, 2008 03:20 PM
low2001gmc
Aug 7, 2008 08:07 PM
montecarloss
Jul 6, 2008 10:12 AM
montecarloss
Dec 31, 2007 07:37 PM
black4x4
Dec 16, 2005 11:55 PM
