TCI shift kit now "No Reverse"
Old Jun 28, 2008 | 09:30 PM
da_vato's Avatar
Default TCI shift kit now "No Reverse"
I obviously did something wrong. It was one of those days that I put everything in two or three times before I got it right. The instuctions that came with the kit werent exactly the same transmission. My truck is a 04 w/4l60E 2wd. The items mentioned in this linke are the only things I messed with. What of these valves could mess up the reverse? http://www.tciauto.com/Products/Inst...76001_inst.htm
for me figure 6 "1-2 accumulator" doesnt have a washer and has a piece that sticks out a bit kinda looks like a half moon but the inside comes to a point.
Old Jun 28, 2008 | 10:02 PM
Derek @ EDO's Avatar
FormerVendor
https://www.performancetrucks.net/fo...ransgo+reverse
See if that helps.
Derek
Old Jun 28, 2008 | 10:11 PM
da_vato's Avatar
theres a bit of a hole in the 1-2 accumulator I think I put the retaining pin through it. Could that be the problem?
Old Jun 28, 2008 | 10:31 PM
FLT's Avatar
FLT
FormerVendor
Are you talking about the accumulator piston housing or the accumulator valve and sleeve? By the way your link does not work for me. A no reverse condition is usually the plate on the back of the valve body is loose or the manual valve is not properly connected. I have never used that kit. If there is a way for you to post the directions I will take a look at them to see if anything else comes to mind. Vince
Old Jun 28, 2008 | 10:34 PM
da_vato's Avatar
the one thats circled. Is there a possibility it could be in the vavle body upside down?
Old Jun 28, 2008 | 10:45 PM
FLT's Avatar
FLT
FormerVendor
It can be installed upside down however it would give you a hard 1-2 shift not a no reverse condition.
Old Jun 28, 2008 | 10:47 PM
da_vato's Avatar
fixed it sorry bout that.
Old Jun 28, 2008 | 10:52 PM
FLT's Avatar
FLT
FormerVendor
If you look at the end of the sleeve, outer most part where the pin is installed, the sleeve has a "V" like structure. The V should be upside down when properly installed. Here is a picture of the sleeve facing in the correct direction.
Old Jun 28, 2008 | 10:53 PM
da_vato's Avatar
I also did the servo. I messed up at first and forgot the last plate but I put that in now.
Old Jun 28, 2008 | 10:54 PM
da_vato's Avatar
I do remember putting the "V" the wrong way now that you say that. But that wouldnt cause a no reverse you say. And another thing does the pin go through the hole?
