TCI shift kit now "No Reverse"
I obviously did something wrong. It was one of those days that I put everything in two or three times before I got it right. The instuctions that came with the kit werent exactly the same transmission. My truck is a 04 w/4l60E 2wd. The items mentioned in this linke are the only things I messed with. What of these valves could mess up the reverse? http://www.tciauto.com/Products/Inst...76001_inst.htm
for me figure 6 "1-2 accumulator" doesnt have a washer and has a piece that sticks out a bit kinda looks like a half moon but the inside comes to a point.
Are you talking about the accumulator piston housing or the accumulator valve and sleeve? By the way your link does not work for me. A no reverse condition is usually the plate on the back of the valve body is loose or the manual valve is not properly connected. I have never used that kit. If there is a way for you to post the directions I will take a look at them to see if anything else comes to mind. Vince
If you look at the end of the sleeve, outer most part where the pin is installed, the sleeve has a "V" like structure. The V should be upside down when properly installed. Here is a picture of the sleeve facing in the correct direction.
