TC, OD, and RPMs
Old Jan 23, 2006 | 09:34 AM
CoonToot's Avatar
Default TC, OD, and RPMs
Let's say that you have a 3000 stall TC. At 70 MPH in 3rd (4L60E) you are turning at (coincidentally) 3000 RPM. Since the tranny ratio changes from 1:1 in 3rd to 1:0.7 in OD, wouldn't you expect a 30% drop in RPMs from 3000 to 2100 when you got into OD? I'm only seeing a 200 RPM drop to 2800. It must be TC related, yet I don't think I comprehend why. Any help?
Old Jan 23, 2006 | 10:04 AM
BigKID's Avatar
Can you confirm that your converter is locking up in OD?
Old Jan 23, 2006 | 10:47 AM
CoonToot's Avatar
I guess that would be a good place to start, huh? I don't have any scanning tools/software. Is there any mechanical method to know if it's locking up?
I also wonder if the higher stall 'confuses' the PCM and therefore keeps the TCC from being engaged?
Old Jan 23, 2006 | 11:07 AM
white1's Avatar
With your foot on the gas, lightly touch the brake petal and see if it unlocks. You should see the revs jump a couple hundred rpm's. Sounds like its not locking.
Old Jan 23, 2006 | 11:23 AM
Wilde Racing's Avatar
How do I change this text
There is a wire that controls the TCC lock up solenoid, you can run a test light to make sure it is locking (or get voltage), but it is much easier to do the test white1 mentioned.
Old Jan 23, 2006 | 12:44 PM
CoonToot's Avatar
I'll try that tomorrow on the way to work. I think you are most likely correct.
Old Jan 23, 2006 | 12:47 PM
CoonToot's Avatar
If the "foot to the brake pedal" test fails, could you tell me which wire to test?
Old Jan 24, 2006 | 05:21 PM
negativeswitches's Avatar
have you recently installed this stall???
have you rechecked the fluid level?
Old Jan 24, 2006 | 10:41 PM
CoonToot's Avatar
Yes and No. I will check the fluid level next. I know for sure that the TCC is not locking. If the fluid level checks OK, what should my next step be?
Old Jan 25, 2006 | 10:50 AM
BigKID's Avatar
Give Allen a call and see if he changed you misfire tables. If you pmc is registering misfires, it will not lock the converter. BTW what size/brand of converter did you install? Neither mine or goshawk's Fuddles would lock up after inital installation because of misfires. This is very common with lighter 9.5" converters.
