TC gone bad or do i need to rebuild my tranny
Old May 19, 2010 | 12:06 PM
CharlyNali6.2's Avatar
Default TC gone bad or do i need to rebuild my tranny
Sup guys, well i drive a 1997 rc stepside silverado with a 4.3 V6 daily to keep miles and weather off my nnbs. anyways the truck runs great shifts really good and it goes into all the gears no problem.. the problem is when i am at cruising speed around 40-65 mph anywhere in between and it is in OD gear. it will sometimes slip down into the next lower gear for a second or two then slip back into overdrive???? sometimes it wont do it all some times it will do it multiple times..ive noticed it wont do it above 70 mph when my rpm's are higher.. so it makes me believe that it is my TC loosing lockup maybe at lower rpms?? i check my tranny fluid and the color is a nice red and doesnt smell burnt.. So im pretty much asking if any of you guys have experienced anything like this before and what was your situation? P.S. when i first noticed it i said i would drive it till it takes a dump on me but that was 6 months ago lol..
EDIT: did not realize i posted in the Dodge section instead of GM
Old May 19, 2010 | 12:23 PM
dlt76028's Avatar
possibly the tcc lockup solenoid is burned up.
Old May 19, 2010 | 12:52 PM
im guessing that is inside the tranny huh? well hell i guess ill just run the **** till it gives out.. i cant really replace anything with out taking it apart down so ill just wait lol
Old May 19, 2010 | 01:34 PM
SILVERBIRCH's Avatar
Take it to Circle D Transmissions they can put it on the scanner a diagnose whats wrong with it.
Old May 30, 2010 | 10:52 AM
BigRed Cummins's Avatar
Could also be a faulty throttle position sensor. Had a '92 Ferd that did the same exact thing and a TPS cured it.
Old Jun 29, 2010 | 11:42 AM
is that something that a scanner could possibly pick up??...i still havent taken it to anyone, but it has been doin it a bit more
Old Dec 23, 2010 | 03:10 AM
LT1STRTOKER's Avatar
Did you figure out your trans, i have a 97 that is doing the same thing, now for about 17 months, found out it is a fix that can be done in the valvebody. Mine did eventually throw a code, but it took it having this problem for almost a year before it did, probably because i only have a 6 mile city drive to work so truck never got to really stretch out in od on those work trips, but when i drove it on the highway mine does the same thing, and my truck is also a 4.3 v6 97 with the 4l60e.
Old Jan 14, 2011 | 08:37 AM
it still doing it lol it has been doing it also since last october so about 15 months. so what all had to be done or it hasnt been done?
blownss27
Aug 14, 2020 08:27 AM
Chevy305
Sep 28, 2015 09:21 PM
trevorh1
Sep 27, 2015 08:47 PM
95RCSS
Sep 18, 2015 01:14 PM
mayko
Sep 7, 2015 12:24 PM
