TA rear end girdle bolts ?
Old Feb 21, 2011 | 10:02 PM
badz24s's Avatar
formerly b4vwannabe (2/4/2012)
Default TA rear end girdle bolts ?
My guy that was installing my truetrac & 4.10s said he couldn't get the TA girdle cover to go on. He said the bolts included with the cover are metric & the housing threads are standard or vice versa.
Anybody else had this problem?
I want to know what threads my housing has so I can try to locate the correct cap head screws & get this cover on. I would rather not have to jack up the truck to crawl under there & remove a stock bolt to measure the threads.
Does anybody know?
Old Feb 21, 2011 | 10:08 PM
tarinitup's Avatar
9 Second Truck Club
That pissed me off during my swap Aswell. I ended up buying correct bolts at supply house.
Old Feb 21, 2011 | 10:11 PM
EVILGMC's Avatar
your ten bolt housing has metric threads. the cover may have come with SAE bolts.
m8x1.25x30mm should get the job done. just check length with the ones that came with your cover....and if you want to be extra sure...take an oem bolt with you to the hardware store to verify the thread pitch.
Old Feb 21, 2011 | 10:16 PM
badz24s's Avatar
That's aggravating, I just found the part # for the ARP bolt kit & they are standard.
Old Feb 21, 2011 | 10:44 PM
EVILGMC's Avatar
The ten bolt has been around for many many years....only the past 15 or so years have been metric. All the rest are SAE.
Old Feb 22, 2011 | 06:32 AM
1Bear's Avatar
I purchased my cover from T/A directly and the 1st thing they asked was if I needed SAE or Metric threaded bolts to be included. As EVILGMC stated, the 10-bolts have been around for eons, so it’s really not T/A’s fault that they come with old standard SAE threaded bolts in the kit, but you would think whomever you got it from would at least make you select which style you needed at the time of purchase.
Old Feb 22, 2011 | 11:15 AM
budhayes3's Avatar
PT's Slowest Truck
When I bought my TA girdle (straight from TA), first thing I found in the box was a note that the newer 10 bolts may have metric bolts, and it listed the necessary size. I was able to find the bolts at Lowe's and Home Depot...they're not stainless or anything but they get the job done
Old Feb 22, 2011 | 02:58 PM
06Sierra2's Avatar
good info. i plan on doing this mod soon as well.
Old Feb 23, 2011 | 10:23 AM
straped for cash's Avatar
I think you can get stainless bolts at Ace Hardware. I have a Ta cover sitting around, also. Waiting for better weather to install it and I still need bolts, too.
pjb1972
Sep 17, 2015 02:06 PM
vipergtrdj
Aug 6, 2015 10:19 PM
Ketis
Jul 23, 2015 12:37 PM
Sdailey
Jul 13, 2015 09:17 PM
