swaping to the 4l80e
Old Sep 10, 2008 | 11:54 AM
bwillbblown's Avatar
Default swaping to the 4l80e
i have a 99 ex.cab 1500 and 2 and overdrive are gone. i got a 4l80e out of wrecked 99 2500. what all do i need to make it work in the 1500? i have the 5.7 motor and the tranny is still hooked to it. the tranny has 900 miles on it.
Old Sep 10, 2008 | 12:35 PM
KySilverado's Avatar
torque converter
Dipstick tube
cross member modification
wiring harness mods
4l80e segmented tune
drive shaft and or yoke changed
probably a crankshaft spacer and flex plate
Old Sep 10, 2008 | 02:46 PM
will the conveter from the 99 2500 work?
Old Sep 10, 2008 | 03:23 PM
nonnieselman's Avatar
Yea you should be able to use it, if its the stock one that's in the 80E.
Old Sep 10, 2008 | 05:25 PM
its factory, where can i get the harness and spacer?
Old Sep 10, 2008 | 06:01 PM
thunder550's Avatar
High on diesel fumes
Read this thread
http://www.ls1truck.com/forums/front...rans-swap.html
Old Sep 10, 2008 | 06:25 PM
No need for a harness
https://www.performancetrucks.net/fo...d.php?t=413157
you can find the spacers and flywheels in the classified section.. Ill also see if my buddy still has his..
Originally Posted by thunder550
I printed that out when i did my swap.... Great write up thats for sure!!
Old Sep 10, 2008 | 06:37 PM
Breeze's Avatar
11 Second Truck Club
Wow thats quite the write up very good info
Old Sep 10, 2008 | 10:31 PM
thank you guys!
Old Sep 10, 2008 | 11:10 PM
skyhighsami's Avatar
no title here
He said that it is connected to the 5.7 and it was a 99. Does it not matter that he will be bolting this up to a Gen III and the tranny was for a SBC? Just a thought didn't know if it mattered.
