Strange Rattle From Bell Housing
Old 04-21-2017, 11:29 PM
gonzo 6.2's Avatar
what strikes me is the old rusty converter re-painted,how many miles on this truck now? you have had the trans out 2x before ,first time was to be pro active before it failed,you had it beefed.And it seems you do not ever run the truck hard,hey rock
Old 04-22-2017, 12:09 AM
therock's Avatar
Hi gonzo 6.2,
Well the history is the Maggie was put on @5k miles and the OE trans made it to 44k or so before a 1st gear rear thrust bearing went out. She has almost 90k now.
Then I had a local trans shop make two attempts with long terms between with a couple of pulls and installs and the OE converter went out in the mix replaced with a stock-ish stall Circle-D.
Inside these two attempts I sent the Circle-D in for a cut & clean.
Then another cut and clean when I changed to Transbuilderguy for the 4.5 build. And again after the loose bolts.
So yeh... she had her scars. The one that came back was a different unit. That was between TBG and Circle-D.
I do not want to beat on my trans builder guy for the bolt mishap. The trans is fantastic and I will not hesitate to use him again or recommend him.
I beat on the truck every time I get in it. I use and abuse her but compared to what you mean by hard I don't know.
Blwn99x
03-22-2016 05:58 PM
rondogacing
03-21-2016 10:54 AM
Jonblarc7
03-20-2016 10:17 PM
05chevy04yfz
03-18-2016 04:07 PM
MOBBN
03-09-2016 11:59 PM
Quick Reply: Strange Rattle From Bell Housing
