steering problem, no power steering to the left
Old Mar 9, 2009 | 04:38 PM
69Boss302's Avatar
Default steering problem, no power steering to the left
As the title states, I've got an 02 Sierra with no power assist when turning left. To the right, it works just fine. No leaks or groans.
Thoughts and suggestions?
Old Mar 9, 2009 | 05:26 PM
KySilverado's Avatar
Steering gear box or rack problem.
Old Mar 9, 2009 | 06:24 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You have a valve sticking in the steering gear. You could try new fluid with a power steering additive before you replace it, never hurts to try. Chances are you'll be replacing the gearbox anyway.
Old Mar 9, 2009 | 06:30 PM
69Boss302's Avatar
Is it possible to rebuild the valves in the rack?
Old Mar 9, 2009 | 07:09 PM
If you purchase a steering gear, it will be remanufactured. It is not something that a person can dis-assemble and repair.
Old Mar 10, 2009 | 08:09 AM
I would replace the rack.
Old Mar 10, 2009 | 02:23 PM
budhayes3's Avatar
PT's Slowest Truck
It is a gear box or rack? Either way, there is a spool valve that goes bad and will cause the condition you described (as mentioned more than once above lol) When this happened to my gear box, it was only available as an assembly, same thing with a rack I believe.
Old Apr 22, 2012 | 10:16 PM
jeffz0rz's Avatar
How do you tell if its the rack, pump, or gear box? Im Having issues steering both ways at times.
dry_kill
11
Aug 28, 2015 09:53 PM
Ketis
Jul 23, 2015 12:37 PM
Denali man
Jul 19, 2015 03:52 PM
1320Chicken
Jul 14, 2015 10:58 PM
lxcoupe
Jul 8, 2015 05:49 AM
