stall and towing. please help
Old Jul 23, 2009 | 12:09 AM
Daryn's Avatar
Formerly darynC-10/23/10
Default stall and towing. please help
okay i have a single cab with 3.73's and a ss3600 stall... and i want to tow an object that weighs 1200lbs.... .. but actual pulling will only be around 600 if that..... ( its a 19 ft boat)
my question is. would my truck be ok for short distances?
i think i may be okay since i have the 3.73's right?
since my truck is a single cab and not a crew cab that helps shave off some weight .....
Old Jul 23, 2009 | 12:12 AM
nonnieselman's Avatar
i wouldnt think twice... got a trans cooler?
Old Jul 23, 2009 | 12:15 AM
Atomic's Avatar
I have a gauge for that
How does it weigh 1200 but you will only be pulling 600?
Youll hardly notice its there...until you go to stop.
Old Jul 23, 2009 | 12:27 AM
bet that converter will flash pretty high with a trailer...
Silver-mod-o towed a 6k# trailer from Virginia to Texas with his.. he had 4.10s and a Yank SS3600.
Daryn's Avatar
im talking about rolling mass vs actual weight... even though the object weighs 1200-1300 lbs. you only need to put a certain about of thrust to get it moving....
and to the other post up there. Yes i do have a trans cooler, i have 2 in line actually, ...
Old Jul 23, 2009 | 12:29 AM
Daryn's Avatar
so i should be fine heh?... i would juat have to keep an eye on my trans temps... they are usually around 160 running "spiritedly"
Old Jul 23, 2009 | 12:30 AM
as long as your trans temps stay under 210 your good... 220* and id be gettin worried.. 240 and id be finding somewhere to pull over to let that baby cool off.
Old Jul 23, 2009 | 01:11 AM
Daryn's Avatar
okay cool, thanks for the suggestions guys!
Old Jul 23, 2009 | 03:59 PM
built408's Avatar
Like stated above, just keep an eye on trans temps. You should be fine.
wickedRCSB
Oct 30, 2015 09:45 PM
Miguel199
Oct 16, 2015 08:04 PM
Wolftrk99
Oct 2, 2015 08:17 AM
bisqikss
Sep 27, 2015 09:40 PM
sTNT971
Sep 26, 2015 06:27 AM
