Stall Question?
Old Jan 31, 2006 | 06:41 PM
Desert Reaper 5.3's Avatar
Default Stall Question?
I read on hear some where that a stall will help you make torque. Just wondering how? What size stall would be good for either a 216/220 or a 212/218 cam, that I'm eventually going to do. What would you do first, cam or stall? Thanks
Old Jan 31, 2006 | 06:45 PM
SSlow 4.8's Avatar
Its good to do them both at the same time... but if i had to choose probably do the cam first so you know basically where it makes the most power and than get a stall that is high enough to launch you at a good spot in your powerband..
as far as it helping you make torque... maybe it'll help you start off at a higher rpm, thus you'll launch at a better rpm where u make more torque... or it'll flash between shifts at a place where you make more torque.. but i do not beleive it actually MAKES more torque for you.
Old Jan 31, 2006 | 09:46 PM
ap2002's Avatar
I got the TB (2500)stall with my 212/218, and it works great!! I have seen people run the 216/220 also with a 2500 stall and it works perfect too...
Old Jan 31, 2006 | 11:59 PM
Thinking about going with a 210/218 551/551. Will that be alright with no stall for a while. Thanks.
Old Feb 1, 2006 | 05:50 AM
tdrumm's Avatar
Is that a Vinci cam? Which LSA are you going with? I have their 062 which is the same specs you posted on a 112 LSA. I've been driving it on a stock converter since June and it is just fine by me.
Old Feb 1, 2006 | 07:54 AM
ap2002's Avatar
you should be ok but the get up and go aint going to be there... I was the same like you, I ran the stock stall after I installed the 212/218, and was going to wait a few months before installing another converter, but after driving it for a week I said hell with it and I installed the TB stall,, it was a night and day difference for sure!
Bluchevypick
Aug 18, 2015 09:11 AM
USMCvet0311
Aug 1, 2015 07:45 AM
Castro45
24
Jul 31, 2015 07:13 PM
vmaxpro
Jul 27, 2015 10:45 PM
