Spool Install questions
Old Aug 22, 2009 | 06:03 PM
Dark Halo's Avatar
Default Spool Install questions
I am looking to install a spool in my 02 drag truck and could use a little info. First off yes it is a drag only truck at this time. My powertrax broke and I need to get it fixed asap. What is involved in installing the spool with c clip axles? I just replaced my bearings when I swaped gears a month or so ago, will I need to replace them again installing a spool? How does a spool work with c clip axles?
Old Aug 22, 2009 | 06:44 PM
stevenc's Avatar
mini spool or full spool?
Old Aug 23, 2009 | 10:10 AM
Dark Halo's Avatar
full spool
Old Aug 23, 2009 | 12:00 PM
KevinF56's Avatar
what about a full detroit locker? that will at least allow you to turn some as opposed to the spool.
Old Aug 23, 2009 | 03:52 PM
1wicked03's Avatar
im looking for a spool also. i have not found one that will work with c clips. nobody makes c clip eliminators for the trucks. i think the detriot is the way to go.
Old Aug 23, 2009 | 05:02 PM
Dark Halo's Avatar
They do make c clip eliminators but I am not sure you need them with a spool that is what I am trying to find out. I also do not want a detriot, I want a spool because this is a drag only truck turns are of no concern to me. I took it off the street 3 years ago. The spool will be lighter so that is the main reason for wanting the spool.
Old Aug 23, 2009 | 05:38 PM
1wicked03's Avatar
yes, every spool i have found you will need c clip elimnators. if you find one that uses c clips, please let me know.
Old Aug 23, 2009 | 09:19 PM
Dark Halo's Avatar
well that sucks, there goes the cheap fix
Old Aug 26, 2009 | 05:07 PM
Bluchevypick's Avatar
You could always find an open carrier and install a mini spool and use factory c-clips. I ran a mini spool for a long time in my old truck and never had an issue.
Old Aug 26, 2009 | 06:14 PM
nonnieselman's Avatar
Yea id go Minispool if you wanna go cheap. they are only about $75 and i just put one in my S-10
Denali08
Aug 9, 2015 04:34 PM
USMCvet0311
Aug 1, 2015 07:45 AM
sauldgold
Jul 23, 2015 02:15 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
