Some final Qs before upgrading the rear...
Old Apr 8, 2006 | 08:18 PM
Tractionless's Avatar
Originally Posted by Grey Silver
Master overhaul kit has a variety of shims, pinion seal and all bearings and races. You're gonna need it.
Tought all I needed was two new carrier bearings (LM-603049) and two new carrier races (LM-603012) and a new gasket... and the fluid. LINK My mechanic will provide shims if they are needed for proper backlash.
If not, can someone provide me with a link to a complete installation kit for our trucks? Thanks
Old Apr 8, 2006 | 09:10 PM
Grey Silver's Avatar
11 Second Club
Sounds like your installer has the hook up. The kit comes in handy for the 1st time you do this at home.
Old Apr 9, 2006 | 12:06 AM
Wilde Racing's Avatar
How do I change this text
Make sure he replaces the pinion nut!!!, you will need a crush sleeve, pinion seal, bearings (if needed), I throw in wheelseals too, but thats me. as well as a housing gasket.
Old Apr 9, 2006 | 08:15 AM
Little 5.3 Wulf Truck's Avatar
Originally Posted by Tractionless
Where did you order them at? Summit sells Strange products but they don't list a ring and pinion for the GM 8.5" 10 bolt.
Nop. Im just gonna upgrade to a posi and steeper gears for a quicker 60' (truck does constant 2.4sec 60's )
I got them from a local rearend shop called Allen's Gearworks. They are just north of where I live in Florida. I did a search and I can't seem to find any gears manufactured by U.S. Gear for your rear, but strange makes good gear sets a friend of mine recommends. Thunder Racing sells gears for your rear from strange!
Old Apr 9, 2006 | 11:38 AM
SlvrSierra4.8's Avatar
Your gonna need front and rear pinion bearings as well, along with a new pinion nut, crush sleeve and the carrier bearings mentioned above. I would give Randys' Ring and Pinion a call and order one of their BK kits. I ordered one last week and it comes with all your bearings(TIMKEN carrier & pinion) as well as gear paint, a new crush sleeve,pinion nut, and pinion seal all for $75.
Old Apr 9, 2006 | 12:00 PM
FILE's Avatar
Where are you getting them installed for $135?
btw, Im getting it all installed for $135
Old Apr 9, 2006 | 12:44 PM
Cuerva's Avatar
11 Second Truck Club
Tiburon, call johnny. He installed my gears for 135 and he knows his ****. He does all the gears for Aggressive. I'll pm you his #.
Old Apr 9, 2006 | 02:00 PM
FILE's Avatar
Thanks.
Old Apr 9, 2006 | 02:34 PM
Where's Agressive located ?
Old Apr 9, 2006 | 04:17 PM
litreddevil's Avatar
Banned
most of the gears r made by the same company and just tag to co companys after they r checked and inspected.
i have ricmond n their now and about to put motive in
