Solid driveshaft on Ex-cab
Old Oct 20, 2005 | 02:48 PM
Default Solid driveshaft on Ex-cab
I have a 2 peice right now. I know the Avalanches and z71 run the 1 peice. I plan on getting a 4L80e at some point. Just wanted to know if it can be done? Is it safe?
Thanks
Old Oct 20, 2005 | 03:17 PM
dewmanshu's Avatar
Moderately Differentiated
Thanks
I actually, changed my one piece to a two piece. I was having HORRIBLE vibration issues and with a long DS it's really hard to trouble shoot...critical speed...blah blah...I wouldn't goto a one piece if I were you. Just cut down the first shaft. Those 4.10's you are looking to install are gonna cause that shaft's rev to pick up anyway. The 2 piece has some parasitic loss I'd imagine, but nothing to worry about unless your looking for that extra .1 in the quarter.
FWW, I have a 3"steel DS and a 4" aluminum DS I'll sell ya if you do decide to go one piece. The are cut down to fit the 80e swap already.
Old Oct 20, 2005 | 05:48 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
A one piece is fine but you need to get it balanced by a professional driveline shop though. Hey Dew how much you want for those axles Im going to be doing an 80e conversion in a few months?
Old Oct 20, 2005 | 08:18 PM
stone150's Avatar
mt Z71 has the one piece ad the only problem i have with it is the scrap metal or something that is traped in it and it sounds gay at low speeds!!!!! AAAAAAAAAAHHHHHHH
Old Oct 20, 2005 | 08:41 PM
dewmanshu's Avatar
The large aluminum stock shaft is filled with foam. Nothing should be rattling inside of it. LOL If there is...serious problem I'd say.
BlownChevy's Avatar
blownerator
25 Year Member
this may be my final mod to the crew.....
Old Oct 20, 2005 | 08:42 PM
dewmanshu's Avatar
I'll shoot you a PM tomorrow morning.
Old Oct 20, 2005 | 08:44 PM
dewmanshu's Avatar
Brian it wasn't that bad of a mod either. I got my two piece from a junk yard...fitted it up and had a really good welding friend make sure it would all stay in place.
Old Oct 20, 2005 | 09:24 PM
stone150's Avatar
well there is, like right at the end, seems like there is a void in the foam and stuff rattles
Old Oct 20, 2005 | 09:27 PM
1slow01Z71's Avatar
Mine doesnt rattle at all sounds like something is up with yours. I have taken mine off many times for transmission **** and it didnt have anything loose in it.
