Slicks on rear, radials on front
Old Dec 3, 2010 | 01:02 PM
foose04's Avatar
Default Slicks on rear, radials on front
Just got these in and heard this might be a hand full on the top end. Any one have problems running a street tire and slick in the rear?
29x11.5x15
Old Dec 3, 2010 | 08:44 PM
built408's Avatar
I've done it, it takes awhile to get use to the slicks. They sway ALOT.
Old Dec 3, 2010 | 10:19 PM
SLOXCAB's Avatar
Top end sway is weird at first but you'll get used to it
Old Dec 4, 2010 | 02:47 PM
JoeGibbSilverado's Avatar
really a handful when u run low pressure...lol you will get use to it
Old Dec 4, 2010 | 04:09 PM
Mangled03gmc's Avatar
Baltimore Whore
I have been 120 with slick on the back and rad's on the front.. It will be a lil different but nothing out of control.. Just don't over compensate..
Old Dec 4, 2010 | 04:12 PM
Atomic's Avatar
I have a gauge for that
How are you going to fit 15s with the rear discs?
Old Dec 4, 2010 | 04:21 PM
quicksilverado's Avatar
Hold the steering wheel straight when the back end starts to sway. It will feel kind of like a boat in the water. The back end will drift around.
Grinding the rear calipers.
Old Dec 4, 2010 | 04:23 PM
Jake99's Avatar
I run those tires on the street and they sway a little but its not bad, however they dont hook to well on the street, they are awsome on the track tho.
Old Dec 4, 2010 | 05:35 PM
tarinitup's Avatar
9 Second Truck Club
Did some testing on my truck with Hoosier slicks and 13.5 psi netted best 60 And less sway. Waiting on results from when you leave on transbrake.
Old Dec 4, 2010 | 05:46 PM
skeet's Avatar
didnt realize sway on the topend had anything to do with a front tiree being radial or not ?
i always thought it was due to tire pressure or worn out slicks? not enough tire pressure it'll sway to much it wont hook?
i run 12 lbs without issues, though i run front skinnies theyre still radial tire, when im below 12 lbs of tire pressure i'll get sway on the topend, anything below 10 lbs it'll really sway
foose i run almost the same tire mines a 29x10.5Wx15 measuring 11.5 across the crown of the tire.i have no issues with sway with 12 lbs of air..
