Size tires for 17" drag rims...
Old Jan 29, 2007 | 07:51 PM
bgray's Avatar
TOTM: June 2007
Default Size tires for 17" drag rims...
curious..what size tires are you guys running in both the back rims(17" factory rims), amd the front tires...??? Drag tires only
Old Jan 29, 2007 | 07:52 PM
bgray's Avatar
TOTM: June 2007
truck isa 99 5.3 rcsb witha 6" flip kit....
Old Jan 29, 2007 | 11:30 PM
James B.'s Avatar
M&H Racemasters. 275/50 R17. 28" diameter. Rims pictured are 8.5"
Old Jan 30, 2007 | 01:12 AM
beefshreadder116's Avatar
i have trouble spinning my 275/55 r17, i have them on 17" denali wheels wich are 9 1/2" wide, my tire width is about 10 1/2-11". they give a little lower gear ratio than a stock hieght and they are nice and wide for traction. im currently running toyo proxies, they are sticky as hell if ur looking to run in a street class.
Old Jan 30, 2007 | 01:16 AM
also i have a two inch drop in the back, but im going lower when i win the lotto. so i made sure i had plenty of room in the wheel well. i would really recomend getting some denali wheels for the back the back spacing is perfect.
Old Jan 30, 2007 | 01:24 AM
James B.'s Avatar
How did you get a 17" Denali rim that wide? Rim width is measured between the insides of the wheel, are you sure you measured right?
Old Jan 30, 2007 | 01:30 AM
i measured it with tire on, so take a 1/4" off each side for the lip, its still atleast 9". i still get 10 1/2 of tire fully pumped up, 11" loafed.
Old Jan 30, 2007 | 02:42 PM
97sicksled's Avatar
I'm running the same as James b. and they are great. M&H Racemasters 275/50 R17's
Old Jan 30, 2007 | 07:08 PM
bgray's Avatar
TOTM: June 2007
what about the front guys?
Old Jan 30, 2007 | 10:52 PM
James B.'s Avatar
You could match the size with a Nitto 450. They make exactly the same dimension tire - 275/50 R17. This is what I'm doing.
