Should my front bumpstops be this close?
Old Aug 9, 2010 | 08:12 PM
BlackGMC's Avatar
Resident Retard
Default Should my front bumpstops be this close?
I was just wondering if my bumpstops should be this close to the lower control arm? As you can see, they are basically resting on the control arm with the truck just sitting there... My truck is lowered 2" in the front with springs.
Old Aug 9, 2010 | 08:13 PM
dlt76028's Avatar
Hell no! I told you to unbolt them lol.
Old Aug 9, 2010 | 08:14 PM
BlackGMC's Avatar
Resident Retard
lol... I wonder if that is why my truck rides like a covered wagon...
Old Aug 9, 2010 | 08:25 PM
Dezert1500's Avatar
Yes, that is perfectly fine. The bump stop will disappear into that casing once your truck is fully bottomed out (if that makes sense). It is a great design. The bump stops should not be removed on the front, as it is unsafe.
Old Aug 9, 2010 | 08:26 PM
qwank's Avatar
mine sit like that too
Old Aug 9, 2010 | 08:28 PM
slamdlsx's Avatar
goes home to find my stock ones. ****
Old Aug 9, 2010 | 08:29 PM
BlackGMC's Avatar
Resident Retard
Why is it unsafe if you remove it?
Old Aug 9, 2010 | 08:30 PM
skolman91's Avatar
x2, or get new shorter ones like i did when i dropped mine..
also you sure thats your actual ride height, looks like its up in the air with the wheel off, just wondered..
dlt76028's Avatar
Looking at my stock truck, there is 1.5" of clearance between the bumpstop and control arm, I would try to get it back to that.
Old Aug 9, 2010 | 08:47 PM
ap2002's Avatar
Buy shorter ones or i believe u can cut/trim the stock ones?
