Should i do a 4L80 swap?
Old Nov 7, 2007 | 05:32 PM
KevinF56's Avatar
Originally Posted by Dirty Dave
How will the 4l80 give him 2-3 more mph in the 1/4. Its heavier it has a higher 1st gear and it has significantly more parasitic power loss. I personally would stick with the 4l60 as long as possible.
the second and third gears i believe are better than a 60e, thus resulting in higher trap speeds.
Old Nov 7, 2007 | 06:04 PM
Mangled03gmc's Avatar
Baltimore Whore
Originally Posted by KevinF56
ask yourself this: do you plan on putting more power in your truck in the future? built 65e's can take 500rwhp. anything after that i'd do a 80e. if your mods stay the same you would be fine with a built 65e. if you plan for HP levels over 500 or so rwhp, buy the 80e.
I agree,
Old Nov 7, 2007 | 07:21 PM
Dirty Dave's Avatar
Third in both trannys is 1-1. Second in the 60 is 1.62-1 the 80 is 1.48-1 I really think the second in the 60 is faster. The only way the 80 is faster is if the higher 1st gear keeps you from blowing the tires on the line IMO.
Turbo 4L60E 3.06 1.62 1.00 0.70
Turbo 4L80E 2.48 1.48 1.00 0.75
Old Nov 7, 2007 | 08:00 PM
Last Call's Avatar
TOTM: January 2007
The 4L80e has a tighter ratio between gears.. When it shifts from 1-2, RPM's only fall to 4700-4800rpm keeping the engine in its powerband. I can do about 62-63mph in first and 101-102 in second with a 63-6400 shift point. With the same combo, my 60e shifted out second at about 90mph. When it went into 3rd, it felt like i hit the brakes. lol
And the fall from 1-2 and 2-3 absolutely sucks in the 60!!
Old Nov 7, 2007 | 08:37 PM
quicksilverado's Avatar
A stock 80e will handle more power than all but the very best built 60e.
Old Nov 7, 2007 | 08:39 PM
Swap to an 80e and you will understand, especially since you have a turbo.
Old Nov 8, 2007 | 06:39 PM
silveradol33's Avatar
Turbo, did I miss somthing? LOL,
Old Nov 9, 2007 | 02:31 PM
well i might get a TNT F1 nitrous system. I do have 4.11's and with my 2800 stall i have been cuttin like 1.8 60'. I have 28" toyos on stock wheels. they hook up well at our local track, but i have been wanting to get a bigger stall.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Three6GMC
Aug 28, 2015 07:56 AM
SloSVO
Aug 11, 2015 07:33 PM
GM-only
Jul 19, 2015 10:48 PM
Nimoryan
Jul 5, 2015 03:50 PM
