Should i do a 4L80 swap?
I have an 02 GMC with cam and full bolt ons. it has 4.11's and a 2800 stall runnin low 13's. My tranny had servo's and a shift kit and it gave out on me. I came across a used built 4L80 for a good price.
-Would a 4L80E do me any good?
-Will it go in with no problems?
-Will it make me faster or slow me down in the 1/4 mile?
-Should I just build my 4L80E, which would cost me more?
-Can i use the same converter?
Bill
You could check out speed engineering.....they sell all the parts individually you would need to do the swap. I wish I would have asked this question about 7 4l60es ago.
A 3 speed is in my future now though.
ask yourself this: do you plan on putting more power in your truck in the future? built 65e's can take 500rwhp. anything after that i'd do a 80e. if your mods stay the same you would be fine with a built 65e. if you plan for HP levels over 500 or so rwhp, buy the 80e.
A 4L80 is going to give you more mph for sure. Proabably about 2-3mph in the 1/4. The 1/4 mile time may be the same or slower depending you get a big enough stall to launch out of the hole and cut good 60's.
How will the 4l80 give him 2-3 more mph in the 1/4. Its heavier it has a higher 1st gear and it has significantly more parasitic power loss. I personally would stick with the 4l60 as long as possible.
