shift solenoids not working untill commanded
Old 08-25-2011, 11:08 AM
Default shift solenoids not working untill commanded
i put my truck back to stock with a stock 60E. the truck starts out in 3rd gear because for some reason my shift solenoids are not turning on. however with my EFI live scan tool i can go into the DVT(f12) tab and command both of them on. when i do that the truck starts off in 1st gear like it is suppose to. so to me that tells me that the solenoids are not bad and it must be something else.
im not throwing any codes. does anyone have any ideas as to what it could be? something in the tune maybe?
Old 08-25-2011, 12:48 PM
Gingervitis Addict
slow67's Avatar
For some reason the PCM is in Limp Home mode. So it's in the tune. Can you post it?
Old 08-25-2011, 05:28 PM
the tune is through nelson and is locked. wouldn't it throw a code if it was in limp mode? i checked for codes with my efi live and a snap on scanner just in case it wasn't tripping the SES light.
Old 08-26-2011, 07:35 AM
anyone else with any ideas? i'm stumped
Old 08-26-2011, 07:53 AM
Suburbazine's Avatar
If no pending codes, it's probably the PCM or wiring to the transmission is not right. Maybe faulty speed sensor or bad wire?
Old 08-26-2011, 08:26 AM
ive checked the wiring to the trans, everything is plugged in, and in the right places. speed sensors were replaced. all the wiring looks good too, no crushed wires that i can see.
Old 08-27-2011, 01:30 AM
Well, if it isn't shifting, then the PCM is looking for a signal it is not receiving.
Jakejack
01-08-2024 10:44 PM
LCHEE
10-24-2020 04:10 PM
ferrellrooster
07-13-2015 09:53 AM
Blackrat48
07-12-2015 07:28 PM
Quick Reply: shift solenoids not working untill commanded
