Shift kit trouble
Old Jan 27, 2007 | 10:00 PM
alanderson1978's Avatar
Default Shift kit trouble
I installed the HD2, Sonnax billet 2nd and 4th servos, and new accumulator pistons. When I tried it, I have no reverse, and from what I can tell, barely moves forward. It's on ramps right now, so I really can't try forward. I'm getting smoke from somewhere, looks like its coming from tranny.
Any quick check to make? I'm about to pull the pan and look.
Thanks
Old Jan 27, 2007 | 10:05 PM
Colby 04's Avatar
boost valve? I've heard of some guys not installing it correctly causing it to rev quite a bit before it would try to move.
As far as the smoke, that's not unusual. You get tranny fluid all over the y-pipe, so a little smoke is normal.
Old Jan 27, 2007 | 10:09 PM
I just read where someone else had trouble with the boost valve. I'll check it first. I was worried because the smoke kinda smells like rubber. I haven't dealt with tranny that much. This is the first thing I've ever done to a tranny besides a filter change.
Thanks for the help.
Old Jan 27, 2007 | 11:21 PM
Yukon 400's Avatar
I installed the same things in my tranny and after a short drive the boost valve popped out and I coulden't pull it out of the garage after. So you may want to check that, or the other thing that many people mentioned to me was the linkage to the valve body.
Old Jan 27, 2007 | 11:54 PM
adam1803's Avatar
Make sure that the boost valve is in correctly and the manual valve is connected.
Old Jan 28, 2007 | 11:12 AM
The manual valve was connected. It was the boost valve. I'm working on getting it back in right now.
Old Jan 28, 2007 | 11:21 AM
Colby 04's Avatar
you owe me a dollar
Old Jan 28, 2007 | 03:08 PM
I'd pay you ten bucks if you would have come over and installed it.
I put two shims in the second gear accumulator, and that with the huge servo makes the 1-2 very firm, 2-3 is pretty firm, and the 4-2 kickdown feels a lot tighter. I drove it about 25-30 miles today.
What would be the effect of leaving the stock boost reg valve in?
Thanks for all the help.
Oobray
Jun 13, 2022 03:38 AM
Blackrat48
Aug 16, 2015 11:56 AM
lycominghunter
Aug 15, 2015 12:26 PM
lxcoupe
Jul 21, 2015 02:12 AM
zaathur151
Jul 6, 2015 10:57 PM
