shift indicator stuck on 2nd
Old Apr 29, 2009 | 06:48 PM
t_thall's Avatar
Default shift indicator stuck on 2nd
went to start my truck the other day and everything would turn on but it would not engage the starter. Upon further investigation i noticed my shift indicator was stuck on 2nd and i couldn't get it off. The gears are shifting normally but it is not registering. I assumed it was my gear indicator switch and ordered one and installed - same thing. Anyone know what could cause this? It is a 4l80e swapped into a 1/2 ton, thanks.
Old Apr 29, 2009 | 08:53 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
Most likley its the PRNDLE switch on the side of the trans at the linkage unless of course thats what you are referring to as the "Gear indicator switch"
Old Apr 29, 2009 | 10:31 PM
t_thall's Avatar
ya thats the one i changed
Old May 1, 2009 | 11:04 AM
t_thall's Avatar
anyone? i also tried unpluging all the wires to the switch and it still says 2nd until i try and shift then the indicator disappears all together
Old May 1, 2009 | 11:13 AM
GMCtrk's Avatar
Did you take the neutral safety switch out of your 4l60e and put it in the 4l80e?
Old May 3, 2009 | 10:43 PM
t_thall's Avatar
in case this happens to anyone else i got it workin. I re-flashed the computer with Hp Tuners and the indicator went back to park and its worked fine ever since, weird.
Old May 3, 2009 | 11:10 PM
bohr898's Avatar
Restricted User
mine is similar it says 2nd but will start and then say park,, once i put it in gear it reads N for like 10 seconds and then finally switches to gear,, i can feel the truck run different when its in gear reading neural.. also my reverse lights dont turn on unless u kinda jiggle to shifter to get it in the right spot to make lights work
i also have 4l80 swap
how did u ""reflash ur ecu" im tuned by nelson,,, ive had a few different tunes and they all do the same thing
Blwn99x
Mar 24, 2023 11:14 AM
Wolftrk99
Dec 3, 2015 08:12 PM
Cammed4ever
Sep 30, 2015 03:38 PM
sTNT971
Sep 26, 2015 06:27 AM
