shift indicator stuck on 2nd
went to start my truck the other day and everything would turn on but it would not engage the starter. Upon further investigation i noticed my shift indicator was stuck on 2nd and i couldn't get it off. The gears are shifting normally but it is not registering. I assumed it was my gear indicator switch and ordered one and installed - same thing. Anyone know what could cause this? It is a 4l80e swapped into a 1/2 ton, thanks.
mine is similar it says 2nd but will start and then say park,, once i put it in gear it reads N for like 10 seconds and then finally switches to gear,, i can feel the truck run different when its in gear reading neural.. also my reverse lights dont turn on unless u kinda jiggle to shifter to get it in the right spot to make lights work
i also have 4l80 swap
how did u ""reflash ur ecu" im tuned by nelson,,, ive had a few different tunes and they all do the same thing
Cammed4ever
Sep 30, 2015 03:38 PM
