Dont u just love it when this happens!!!
Old Apr 30, 2009 | 05:30 PM
peterls1's Avatar
Default Dont u just love it when this happens!!!
So Drivin to work this mornin doin 70 on the highway and all the sudden it was like i threw the bitch in neutral......NO GEAR WORKS, NONE! No loud noises, no pop, no grinding, nothin, just decided to go on its own little vacation from working.Checked the fluid and smelled and looked fine but noticed when running it was high on the stick like maybe the pump gear or sumthin was out. No clue yet what it may be but already started pullin the tranny to send to a friend and the converter back to the shop where i bought it. I will keep u guys updated so that we may learn somethin from this.
Old Apr 30, 2009 | 05:34 PM
00Silv4.8's Avatar
4L60Es FTMFW!!!
sucks man, hope you get the truck back up soon
Old Apr 30, 2009 | 05:35 PM
charcold-bowtie's Avatar
lol, I guessed the topic just from the title
Old Apr 30, 2009 | 05:41 PM
peterls1's Avatar
4L60E built, shift kit, servos, billet input, etc.....it has broke once b4 but it was the sprag im told by the biulder musta been jus a bad part from the get go, hes a member who built it and a good at it so hopefully and im sure hes hopin too its not the tranny but the convertor
Old Apr 30, 2009 | 05:45 PM
00Silv4.8's Avatar
I would think it would smell if you fried a clutch. Something had to have just "let go". I would hope its something easy
Old Apr 30, 2009 | 05:52 PM
peterls1's Avatar
Its cool nothin a BFH cant fix, or at least that'll fix some aggression issues for now
Old Apr 30, 2009 | 07:12 PM
viciousknid's Avatar
Where's the Beef?
Neutral switch maybe? can that do it?
Old Apr 30, 2009 | 09:27 PM
peterls1's Avatar
Dunno bout that. But regardless its comin out to go ahead and check the stall convertor and run through the tranny AGAIN!
Old May 1, 2009 | 03:54 AM
nonecktribe's Avatar
dang that sucks...hope you get up and running again....i live in burleson...wut kinda truck yah got might have seen you on the roads?
Old May 1, 2009 | 08:18 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Bet your pump is the issue. The 13-vane "ring" inside the pump has failed on me once. Talked to a friend of mine who has a friend with the same symptom.
Crack the pump open & see. May as well go through the entire trans to make sure no trash or residual debris made it's way thru. Check the clutches while you're in there. No sense in not replacing those with new ones since the trans is apart.
