Rotor Help
Old Oct 11, 2008 | 06:01 PM
dimedsbc's Avatar
Default Brakes HELP NBS
i have one side tore down and put back together.... well got to the next side and got the caliper off and now i am trying to get the bracket off around the caliper to get the rotor off..... what the hell are those two 18mm bolts torqued to? the other side was a little tight but man i can not get this to budge at all!! i am using a 10" breaker bar and a 18mm 6pt craftsman socket....... any help ASAP!!!
Old Oct 11, 2008 | 06:14 PM
95 bright teal's Avatar
here you go.https://www.performancetrucks.net/fo...take+rotor+off
Old Oct 11, 2008 | 06:28 PM
dimedsbc's Avatar
bump it up
Old Oct 12, 2008 | 01:21 AM
dimedsbc's Avatar
bump it up
Old Oct 12, 2008 | 01:23 AM
Stoichiometric's Avatar
Use a propane torch and heat the bracket the bolt threads into just enough to get the bolt to break loose. They have a factory loc-tite, the heat will help soften that as well as help the bracket 'grow' to let the bolt out.
Old Oct 12, 2008 | 01:59 AM
dimedsbc's Avatar
damn i dont have anyway to heat it up just basic hand tools... maybe after some more soaking it will break free
Old Oct 12, 2008 | 11:25 AM
I would run down to the hardware store and pick up a propane torch and camping fuel bottle. I have used this countless times getting things unstuck, saves headaches.
.J.
20
Mar 4, 2016 03:03 PM
cousblake11
Sep 9, 2015 06:52 PM
Alco
Sep 4, 2015 04:08 PM
