Rotor Help
i have one side tore down and put back together.... well got to the next side and got the caliper off and now i am trying to get the bracket off around the caliper to get the rotor off..... what the hell are those two 18mm bolts torqued to? the other side was a little tight but man i can not get this to budge at all!! i am using a 10" breaker bar and a 18mm 6pt craftsman socket....... any help ASAP!!!
Use a propane torch and heat the bracket the bolt threads into just enough to get the bolt to break loose. They have a factory loc-tite, the heat will help soften that as well as help the bracket 'grow' to let the bolt out.
