ring and pinion advice/ have a t56
Old Apr 24, 2011 | 01:12 PM
joelm86's Avatar
Default ring and pinion advice/ have a t56
man i got a 2000 with a 5.3 with whipple 9 pounds with gt2-3 cam+ some spray, with t56 transmission but still got 3.42 gears in back and need some advice. getting truetrac, but want to know what ring pinion size would be the best for 1/4 mile, this is not my daily driver so can be agressive but do drive on street every weekend. any help is good help richmond, motive, yukon what would be the best, also looking for a god girdle. oh this thing still has rotors in rear, and t56 has a performance clutch and has chatter some extra info
Old Apr 24, 2011 | 03:44 PM
vanillagorilla's Avatar
What T56 do you have? By that I mean what did it come out of? An F-body or a GTO? The reason I ask is because your rear gear choice should depend on the 1st gear ratio in the trans. With a blower and an f-body T56 I say nothing less than 4.56's.
Old Apr 24, 2011 | 05:13 PM
joelm86's Avatar
it came out of a 2002 camaro everything besides the input and output shaft has been upgraded and i was thinking more like a 4.30 gear cause of the blower man or am i wrong. and is 4.56 gear good on street to or what
Old Apr 24, 2011 | 07:54 PM
joelm86's Avatar
and does any one know the part number for a 4.56 ring and pinion for a 8.5 10 bolt 30 spline
Old Apr 25, 2011 | 05:22 PM
I ordered my 4.56's from summit, perfect gear for a t56.
Old Apr 25, 2011 | 07:17 PM
midevil1's Avatar
5.13's
4.88's are sweet too
Old Apr 25, 2011 | 10:44 PM
joelm86's Avatar
o k thanks man im going to order a 4.56 most likely it will be a richmond but damn you really have a 4.88
Old Apr 25, 2011 | 11:54 PM
midevil1's Avatar
I have 5.13's in my truck. 70mph and 1900rpms... I have true trac and Yukon 31 spline axles. ARP studs on 5 lug conversion. and LPW girdle.
Old Apr 26, 2011 | 12:06 AM
HEADHUNTER92's Avatar
joel86...i dealt with rons machine for my gears when i put a trutrac and 3.73 since its a daily driver and you cant beat his prices no where. you even get a discount for being an ls1tech member if you mention it to them
Old Apr 26, 2011 | 03:18 PM
joelm86's Avatar
ok cool thanks for info guys will deal with rons machine service looks like they do got some good deals and will mention im on ls1tech, but i did find a new 4.56 gear for sale but want to check if this is right part number 08369-69-0167-1 and thanks guys for all info great help
OHsixLS3
Nov 22, 2015 07:45 PM
turbo6c3
Oct 5, 2015 06:11 PM
Tigger Welder
Oct 1, 2015 08:41 AM
jtphelps289
Sep 29, 2015 12:00 PM
