Ridetech Coil-overs Installed gmt-800
Old May 15, 2015 | 10:53 PM
  #311
TheBeeblebrox's Avatar
I hear you on that, one of the guys at work mentioned it too, its what RT included in the hardware kit.
Old May 16, 2015 | 12:03 AM
  #312
Blown06's Avatar
8 Second Truck Club
I saw where someone mentioned above about the upper ball joint possibly fitting different in McGaughty or Bellech spindles.
Don't forget guys, the upper ball joint hole has to have a 1/2" drill bit run through it for the new ball joint to seat properly.
Old May 16, 2015 | 12:40 AM
  #313
Can't comment on the McG's but Belltech's fit just fine. - milesp07 said he had to machine the McG's so the lower balljoint could move freely, plus with those you only get 1" of drop.
Yea you remove .023" of material to clear the balljoint stud.
Old May 16, 2015 | 09:11 PM
  #314
indianbullet's Avatar
Registered User
I have to tag my self for great information here.
Old May 16, 2015 | 10:04 PM
  #315
Rompn's Avatar
Interested in doing this swap however I'm running an 05' Sierra that has the odd front suspension setup utilizing torsion bars instead of coils and swing steering instead of rack and pinion. I know Atomic makes some mounts for the 4WD guys but not sure if this is identical to a 4WD front end.
Old May 16, 2015 | 10:17 PM
  #316
Yes 2wd t-bar and 4wd suspension are the same and they are different from 2wd coil-spring front ends.
So all you need is Atomic's mounts.
Old May 17, 2015 | 09:51 PM
  #317
settlemoore's Avatar
Really good info in here guys. I've put maybe 7k miles on this set up and its the best mod I've done so far...even just slapping them in without the arms, just completed a 350 mile trip and it rides like a dream
Here's how it sits now
Old May 17, 2015 | 10:34 PM
  #318
Vortec350ss's Avatar
Sharp ride!
Old Sep 3, 2015 | 07:57 PM
  #319
Curious guys...when I jack my truck up the springs are loose, like they can move up down and all around. Is this a bad thing? Perhaps I'm not using the correct length spring? Or does it not really matter
Old Sep 3, 2015 | 08:09 PM
  #320
No, it just means you are low, on my old set up to sit level my passenger side coil was like that. It doesn't hurt along as you're not bottomed out in travel.
