ride height
Old Aug 17, 2007 | 02:50 PM
dyers98's Avatar
Originally Posted by bluecajun5.3
just remove the blocks and put them on top the axle so you can still use your stock 4wd u-bolts.
Thanks - Good idea. I am going to go that route.
Old Aug 17, 2007 | 03:41 PM
TXARKITEKT's Avatar
An easy way to figure out what you need to do is measure from the ground to the top of the wheel well--front and back. Whichever is higher, drop it to even out with the lower. Usually the back is higher.
If you want ride height, then you can crank the torsion bars up front. But beware, some people complain about the stiffened ride and some have front end alignment issues. You also can wear out some of the front bushings easier.
But if you don't care about the ride height, then do the block swap on the rear axle. Easy, no extra parts needed, and straight forward. Doesn't get any easier. Good luck!
Old Aug 17, 2007 | 11:36 PM
IMD's Avatar
IMD
Banned
my 4wd truck is lowered 6/6. i think it rides just fine. just remove the stock blocks, and get some 2wd u-bolts from the dealer.
BCraven1018
Nov 2, 2015 07:18 AM
dantheman1540
Nov 1, 2015 02:59 AM
01silvy
Sep 26, 2015 10:20 PM
old motorhead
Sep 18, 2015 03:33 PM
Dezmo
Sep 9, 2015 02:09 AM
