ride height
An easy way to figure out what you need to do is measure from the ground to the top of the wheel well--front and back. Whichever is higher, drop it to even out with the lower. Usually the back is higher.
If you want ride height, then you can crank the torsion bars up front. But beware, some people complain about the stiffened ride and some have front end alignment issues. You also can wear out some of the front bushings easier.
But if you don't care about the ride height, then do the block swap on the rear axle. Easy, no extra parts needed, and straight forward. Doesn't get any easier. Good luck!
BCraven1018
Nov 2, 2015 07:18 AM
