Retune necessary for 4.10's?
Old May 8, 2007 | 04:53 PM
zo6freak's Avatar
Default Retune necessary for 4.10's?
just wondrin if i have to get a retune for my 4.10's. I have 3.73's now and im considering getting the 4.10's because i just got some new tires, i went from a 30.1" diameter to a 32.8" diameter tire. what benifits would i see from getting it retuned? I was told that when i put them in, they will bring me back to where i was before the tires power wise. Is this true?
other than the above mentioned items, i wont have any abs or tranny issues from this swap will I?
any help would be appreciated.
thanks
Old May 8, 2007 | 05:03 PM
Derek @ EDO's Avatar
FormerVendor
your speedo will be off by a couple MPH if you dont.
Old May 8, 2007 | 05:08 PM
RoosterMcCandles's Avatar
Your truck will also show more mileage than it should the longer you go...
Old May 8, 2007 | 05:11 PM
xsports33's Avatar
you will have ABS issues if you don't retune.
Old May 8, 2007 | 05:23 PM
zo6freak's Avatar
what kind of issues? Any of them serious? Are these problems guaranteed to happen?
Old May 8, 2007 | 05:34 PM
xsports33's Avatar
you'll throw a check engine light or an ABS sensor light because correlation between your transmission spinning and your wheels spinning will be different. I don't know if it will affect drivibility, but the annoying light will be on.
Old May 8, 2007 | 05:39 PM
zo6freak's Avatar
ok kool. i used one of those online gear ratio calculators and i plugged in my old tires vs my new tires and it said in order for my truck to be stock again, i would need to put 4.07 gears in. so in theory 4.10's get me back to where i was before plus a slight gain on the low end. is this true?
so all i need to do is get the ecu reprogrammed for the 4.10's and im home free?
sorry man
Old May 8, 2007 | 05:43 PM
xsports33's Avatar
Sounds like you got it down. Any handheld programmer can adjust for new gear ratio's, if you're going the ECU route i hope your getting a lot more than just your gears tuned. ECU programs are $$$
Old May 8, 2007 | 05:47 PM
trblmkr's Avatar
So the hypertech programmer will make the necissary adjustments after switching to 4.10's if so that would be great my gears go in late this week or early next week waiting on parts...
Old May 8, 2007 | 05:49 PM
zo6freak's Avatar
yea i currently have a westers tune that i am happy with so ill just send em my core and have them write a tune on it.
once i get the new tune, can i just clear the codes for the abs? I dont know if its like that dreaded crank relearn procedure i had to do...
