Removing overload springs?
Old May 10, 2014 | 11:56 PM
KisenS's Avatar
Registered User
Default Removing overload springs?
Removing overload springs. Should I do it? Anyone have experience with removing them or how it effects performance? I wanna pull them off a 2000 silverado.
Old May 11, 2014 | 12:05 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You'll need to install some sort of traction bar setup to eliminate wheel hop induced by spring wrap after removing the overloads. Many have done it, including myself. There are a few different options out there for your truck.
Old May 11, 2014 | 12:55 AM
timmay208's Avatar
im debating taking mine out so i can get the back of my truck down a little more, but gotta get custom u bolts as i already have my blocks out
not sure if its worth the hassle being i tow a boat during summer time
Old May 11, 2014 | 09:26 AM
black00chev's Avatar
Slowest turbo build ever!
If you put helper bags on to act as overloads I don't see a problem towing.
Old May 11, 2014 | 10:03 AM
timmay208's Avatar
Problem is finding a helper bag thats small enough, prob have to make something custom
Old May 11, 2014 | 12:13 PM
WICKEDOWESIX's Avatar
I have them off but a traction bar is a must because the wheel hop/axel wrap
Old May 11, 2014 | 07:40 PM
unless he's lowerd a crap ton, hellwig makes a nice bolt in helper kit that should fit just fine.
Old May 12, 2014 | 07:51 PM
KisenS's Avatar
Registered User
Do I need different U-bolts? Ask that's done is, 2" drop shackles so far.
Old May 12, 2014 | 07:57 PM
timmay208's Avatar
i took blocks out but i had to put spacers on my current shackles as i was out of thread if i go anymore i have to get different ubolts
Old May 12, 2014 | 08:48 PM
BADRIDES's Avatar
I installed 2 inch hangers,2 inch shackles and pulled overload in rear to achieve a 5 inch drop. I had to put washers on top of the nuts cause I didnt have enough thread and worked out fine. I have Belltech Street performance shocks on rear and it rides great.Truck is a 2000 GMC regular cab.
jtphelps289
Sep 29, 2015 12:00 PM
chvy=power
Sep 8, 2015 11:06 AM
USMCvet0311
Sep 4, 2015 09:43 PM
Mzay
Jul 6, 2015 11:05 PM
