rearend ?
Old Jun 10, 2006 | 08:55 PM
sd155racer's Avatar
Default umm
My G80 3.73 let loose on the drag strip line - spiders got loose in the carrier and went bang - I've got a nice video of it if you want to see -
http://www.stevebonelli.com/snap.wmv
After this, I replaced the 3.73's with 4.10 front and rear...and after another 10k, the rear end let loose again - worse this time, the small 8mm bolt through the spider retainer sheared in 3 pieces cuz the spiders got sloppy in the carrier. Took out the entire rear end, including the new ring and pinion. just got done replacing it a couple days ago - GM has a new design spider which is supposto fix this problem.
Old Jun 10, 2006 | 09:38 PM
litreddevil's Avatar
Banned
spending that much money with front and rear gears i would have put a eaton in with the gear change
97_ek
Sep 23, 2015 09:16 PM
600 horses
Sep 10, 2015 11:01 AM
03chevytruck
Aug 25, 2015 09:08 PM
BlackDog
27
Jun 4, 2004 09:57 AM
