Rear End Whine
My dad's 02 suburban is makin some rear end bearing whine. It does it worst when the driveline is loaded. When you unload the rear, it still whines but is much quieter. If I remember correctly if you hear whine under load it means the pinion bearing is the culprit. Is this correct? Any other ideas out there?
Originally Posted by TG02Z71
I'm guessing it a G80 rear axle not an open diff?
How many miles on it to date?
Has he ever had the fluid in the rear end changed? If not, its definitely overdue. I'd start there first. Its a fairly cheap fix, if thats all it is. I just did mine this past weekend, took me about 30-45 minutes and about 25 bucks for the fluid.
Originally Posted by cary00silve
I already told him to do that and see if it helps any. Supposedly the service interval is 100,000 miles on the synthetic diff fluid. I changed mine every 25 cause I'm **** like that.
I used dino oil when I did my eaton install and have had zero problems.
Don't for get the friction modifier!! 4oz bottle.
I have been told by many here not to use synthetic oil in the diff.
TimDave217
Aug 24, 2015 04:38 PM
shupe
Aug 5, 2015 06:45 PM
