rear disc brake conversion
Old Jun 10, 2007 | 04:10 PM
Default rear disc brake conversion
where can i get the caliper braket to do my own rear disc brake conversion i have drums now and they aint cuttin it. can i go to the dealer and just buy the parts?
Old Jun 10, 2007 | 04:12 PM
YeLLow Fever's Avatar
try the junk yard
Old Jun 10, 2007 | 09:07 PM
budhayes3's Avatar
PT's Slowest Truck
Could go to the dealership, or get some aftermarket stock replacement parts (Napa, Autozone, etc.), or get some performance stuff from a company like SSBC, Brembo, Wilwood, etc.
Old Jun 10, 2007 | 09:40 PM
Bill Reid's Avatar
So, the rear axle housing is the same?... say from 2001 to 2006... just that drums replaced the disk setup?
Thanks,
Bill
Old Jun 10, 2007 | 10:52 PM
budhayes3's Avatar
PT's Slowest Truck
I *think* they're the same...maybe try a search in the suspension and drivetrain section...I think some folks have done this before.
If a mod could move this thread over there, it may get more responses also.
Old Jun 11, 2007 | 06:51 PM
2006 8.1's Avatar
I think they are the same axles, just different backing plates. Should be able to buy all the parts from GM and do it yourself, or find a wreck and pirate the parts that way.
Old Jun 11, 2007 | 06:53 PM
laynlow77's Avatar
ive got a full rear end minus the housing with everything needed off of an 04!
Old Jun 11, 2007 | 09:28 PM
skyhighsami's Avatar
no title here
If all you need is the hardware that would seem like a very simple swap. Would you need a proportioning valcve and upgrade the master cylinder?
Old Jun 11, 2007 | 09:41 PM
laynlow77's Avatar
from what i understand its fine without one. rear braking power is still 70/30 whether its drum or disc in the rear.
the biggest problem is making sure that the master cylinder allows the pressure needed for disc, which i believe it will.
Old Jun 11, 2007 | 10:11 PM
no title here
So all I need to do is swap all the stuff off a disc rear end. If I went to a junk yard and bought the rear end out of a truck that had disc and 3.73s or 4.11s would I be able to just bolt it in? Is there anything that I should look for when trying to make a pruchase?
