pinion angle
Old May 12, 2015 | 03:22 PM
121's Avatar
121
Default pinion angle
What should my pinion angle be at for a drag setup. 08 rcsb 2wd 4/7 flip kit with caltracs
Just curious what degree works the best I'll be having my shop do it while I'm out of town
Old May 12, 2015 | 03:33 PM
GMCtrk's Avatar
There's no way to answer this question without knowing the actual measurements on your driveline.
What I've seen posted repeatedly is an misunderstanding of what pinion angle really is. Most think it's the relationship of the rear end yoke to the ground. In reality, what we are after is the relationship of the driveshaft to the rear end pinion. This angle should be equal and opposite to the transmission-driveshaft angle. Usually we allow 1-2 degree of upward rotation of the pinion under power, however since you have Caltracs, theoretically, there shouldn't be any rotation.
Do you have a 1 piece of 2 piece driveshaft? 1 piece should be pretty simple, 2 piece adds more complexion and I'm still trying to figure it all out on my setup.
Old May 12, 2015 | 04:51 PM
121's Avatar
121
Ok I have a one piece shaft and 62 inches long I probably wanna be in the 3° range
Old May 12, 2015 | 05:21 PM
GMCtrk's Avatar
3 degrees is a bit much for ideal U joint operation
Old May 12, 2015 | 05:37 PM
121's Avatar
121
I just want it at the best angle so my suspension caltracs etc all work so I get max traction with these slicks
Old May 12, 2015 | 05:39 PM
MechE's Avatar
pinion angle is the angle of the pinion in relation to the angle of the tailhousing...not to the driveshaft. should be about -3* for a leaf spring truck
Old May 12, 2015 | 07:54 PM
vmaxpro's Avatar
Ive got caltracs and a flip. My driveline angles are trans -2.3, driveshaft -1.2, and oddly enough pinion -2. No vibe whatsoever and hooks hard
Old May 12, 2015 | 08:23 PM
George C....'s Avatar
Formerly ScreamingL
target between -2 to -4 with caltracs
Old May 12, 2015 | 09:06 PM
121's Avatar
121
Awesome thanks for the help guys
Old May 12, 2015 | 09:31 PM
blown02408's Avatar
02 w/ lowest mileage 2800
The angle between the pinion and the driveshaft, and the tailhousing and the driveshaft should always be equal and opposite. The pinion and the tailshaft should also always be parallel to eachother. So if the pinion is set at -2 degrees to the driveshaft then the trans tailshaft needs to be +2 degrees to the driveshaft the resultant angle is 0 degrees. I just went through this with my truck which is lowered 7"s in the rear and ended up having to raise the trans mount 2-1/2"s and modify the engine mounts to make all the driveline angles happy again. Granted I should mention that I've seen some pinion angles in drag racing that defy logic, but work for some people.
