Question about torque converters
Old Jun 8, 2007 | 04:08 PM
Bish's Avatar
No problem as a daily driver IMO. I can really tell the difference in a couple areas. When you launch from stop, I seem to get much more torque from a stop and revs a bit more than stock. Normal "slowly applying pressure to gas pedal" does not feel any different than stock. When the lockup clutch engages (triple disc), it feels like another gear compared to stock. Towing a 5,000lb trailer and starting from a stop is noticeably different than stock. Significantly more rpms as you start moving. Seems to flash higher with a trailer which makes sense at least to me.
I was worried about towing and daily driver attributes. Chuck at FLT convinced me this would be a good choice and he was spot on! I would do it again in a minute.
Old Jun 8, 2007 | 04:39 PM
ReSpAwN DeMoN's Avatar
awesome thanks guys!
Old Jun 8, 2007 | 05:13 PM
nonnieselman's Avatar
Originally Posted by ReSpAwN DeMoN
your at a redlight and you slowly just put your foot down on the gas to accelerate up to speed limit. What would happen? It'll behavy stock and just go? or it'll have to rev up a good bit first.
Now what would happen if I was sitting there and I nailed the gas pedal? My tires would spin?
At a red light if your just easing around and aint got nothing but time, it would act just like a stock converter, maybe 200-300rpms more.
While sittin there and you nailed the throttle it would shoot to ~2400 (if you have a 2400 stall) not sure about what tires you got and all..
With my stock converter it would just chirp the tires.
Now with the TT3000 and STS kit, first gear just puts the tires into a smoke machine...
Old Jun 8, 2007 | 05:57 PM
I got LT265/75/R16 with all-terrain tread on it..
they are starting to wear down so I'll probably be replacing them with that same size but all season tread instead.
Old Jun 8, 2007 | 09:27 PM
04 ss man's Avatar
If ur getting a FLT just ask Chuck what u need. I just got my trnas back and call PI and they gave me a part # that I gave to Chuck. I wanted a 3,000 10.5 for my truck cause it is so heavy. He called me back and told me I needed another convertor. I ended up with a 2,600 but with the weight of the truck it stalls to 3,000. Listen to Chuck he no's what he is talking about. I counldn't be happier.
Old Jun 8, 2007 | 10:25 PM
you got an ss?
a regular 'ol ecsb would be heavier then an ss huh?
Old Jun 9, 2007 | 01:03 AM
you got an ss?
I believe he has you be a few hundred pounds.... All Wheel drive and transfer case and all..
Old Jun 9, 2007 | 09:22 AM
I forgot about that part!!! ya that's true..
for a second I figured it was like the lightning compared to the regular f150's...
Old Jun 10, 2007 | 04:56 PM
04 ss man's Avatar
Yea it weighs 6400lbs with the factory 20's. Not sure what it ways now, I'll find out next time I am at the track.
TAPyvehc93
Jul 23, 2017 10:54 PM
OLD BULL
Aug 1, 2015 05:00 PM
BennyB
Aug 1, 2015 08:48 AM
KyleW707
Jul 29, 2015 08:17 AM
JordanH
Jul 14, 2015 03:46 PM
