07 NBS factory block??
Old Jun 10, 2007 | 12:31 PM
StealthSierra's Avatar
Default 07 NBS factory block??
is this removable?
looked underneath my truck the other day and am wondering if i can just remove it... like a free leveling kit.
Old Jun 10, 2007 | 01:06 PM
ZZebes's Avatar
Yes, you need 2wd U-bolts and maybe a shim but probably not
Old Jun 10, 2007 | 01:36 PM
it is 2wd... so just pulll it out and bolt back together? no lil hangups or extra parts...
Old Jun 10, 2007 | 01:59 PM
ZZebes's Avatar
no you need a shorter U-bolt unless yours have enough thread to tighten and torque them
Old Jun 10, 2007 | 07:07 PM
VTODD's Avatar
i pulled them out of mine and used nothing extra to tighten it back up. just pull the blocks and reuse the stock bolts. worked out fine and dropped the rear about 1.5 inches.
todd
Old Jun 10, 2007 | 08:44 PM
niugnep's Avatar
Gonna need more than that block to level it!!!
Not all the u-bolts are threaded the same it appears so make sure you don't bottom out when torquing or you won't get your clamp up. Some guys are adding thick spacers/washers under the nut to make sure if its close (looks better too without 2" of thread hanging down unless you plan to cut it off).
Torque is 74 lbs/ft on the nuts BTW (1500 series).
Just installed (still have dust in my eyes) the belltech 2" drop shackles, made a small but nice difference. Plan on removing the blocks as well possibly.
signguy62
Sep 20, 2015 02:05 PM
1bad2k
Aug 18, 2015 09:50 PM
Denali08
Aug 9, 2015 04:34 PM
jmarkway
Jul 18, 2015 09:23 PM
signguy62
Jul 16, 2015 05:43 PM
