Question about 14 bolt install
So I’ve had this axle for quite some time now, finally got it painted and have pulled the bearings and seals. Before I pulled the axles I obviously pulled the pinion shaft and the yoke has probable been spun in moving and painting it. Could that mess anything up when I’m putting it back together? Will I be able to tell? When I’m putting the pinion shaft and the c clips in? Total noob question I’m sure just trying to not mess anything up. Thanks!
If you left the pinion gear in and only removed the parts necessary to get the seal out you need to make sure everything is clean when you replace the seal. You will also need to reset the bearing preload when you re assemble it. Assuming your getting a new seal and crush sleeve? Other wise I hope you measured the Preload if your reusing the old crush sleeve...
ok thank you, basically just double checking that I wouldn’t have messed up the alignment of anything by rotating the yoke in painting and transport. Basically what I’m hearing is as long as the pin goes back in then it’s properly aligned and we’re good to go. Thanks!
arthursc2
Dec 11, 2016 09:36 AM
Ihasfip
Aug 21, 2014 11:21 AM
Gadgetized
Jun 23, 2013 10:09 AM
