PT.net Gear Install How-To
Old Jun 10, 2021 | 11:40 PM
  #91
Atomic's Avatar
I have a gauge for that
Reading this makes me never want to do gears ever again 😂
Old Jun 10, 2021 | 11:44 PM
  #92
mikerlew's Avatar
I feel you there. Once I finish this I won’t be doing gears for a while 😂. I’ll do em’ again, rest assured haha
Old Jun 11, 2021 | 01:00 PM
  #93
RedXray's Avatar
100% Redneck
Originally Posted by mikerlew
I might try again with thinner paint so it shows easier.
If you put some drag between the pinion & ring gear when rotating you'll get better contact on the painted teeth. Rotate the pinion while holding the ring with a shop rag works for me.
Old Jun 11, 2021 | 02:51 PM
  #94
mikerlew's Avatar
Good Idea. I will do that. Appreciate it RedXray!
Old Jun 24, 2021 | 01:24 PM
  #95
mikerlew's Avatar
Default Troubleshooting Gear Pattern
Gotta love accidental erasing your post
anyways.
Hello everyone!
So I got access to a press and got the original shim for the pinion. It was 0.034” or so.
I assembled it all together and put the gear paint on at 3 points. Here was my conclusion.
Point 1 looked great. Not perfect but great.
Point 2 was completely out of spec and it said I need to add thickness.
Point 3 was in the middle. It was decent but not perfect.
Now I’ve had this issue for the last few weeks, and I’ve put the carrier in and out at least 4 dozen times, so I don’t think it’s cockeyed. The shims are straight, and the bearings look good. The pinion is at 20” preload or so, and the right pinion depth for now. Backlash isn’t excessive.
I took apart the ring and pinion twice now to make sure it’s even and flat. It all looks great, but the markings still show otherwise.
I’d appreciate any input, ideas, or insight. Thanks guys!
Photos
Point 1, not to shabby. Not perfect but good.
Point 2, What is happening here? Way outta spec
Point 3, Not too terrible, but definitely not great
Will
Jan 17, 2018 07:52 PM
Dusty05
Feb 13, 2015 01:17 AM
lifted99GMC
Dec 29, 2004 06:52 PM
TwoFast
Jan 15, 2004 08:00 AM
agreif
Oct 20, 2003 07:56 PM
