popping when turning
Old Jun 16, 2013 | 11:05 AM
bbowerman's Avatar
Default popping when turning
hey guys my truck has developed a popping sound when making a hard right or hard left it isn't a loud pop and sometimes it doesn't do it I have hear it could be my intermediate steering shaft? also heard that could be ball joint idk what I was wondering is there any way to check those without tearing the front end apart because I don't want to tear it apart and then that not be the problem. thanks
info 2001 ecsb 2wd 208,000 miles
Old Jun 16, 2013 | 12:23 PM
asap216's Avatar
Sounds like ball joints. Jack up the front end and with one hand grab the top of the tire and with the other hand on the bottom and try to move the tire inside and out. Shouldn't have any play.
Old Jun 16, 2013 | 12:54 PM
texasglock23's Avatar
I second ball joints
Old Jun 16, 2013 | 08:20 PM
bbowerman's Avatar
I guess I should start looking before I post I jacked it up and it moved like you said but its bit a ball joint its an upper control arm bushing hope this helps someone else
Old Jun 16, 2013 | 09:50 PM
262_NBS's Avatar
The engine crossmember can develop a pop or "snap" sound as well.
Old Jun 16, 2013 | 10:20 PM
jschrock's Avatar
Is it in the front for sure or could it be in the rear?
Do you have a g80?
Old Jun 17, 2013 | 02:36 PM
bbowerman's Avatar
nope its the old spider geared 2wd lol I am buying a new upper control arm asap with Moog bushings and Moog ball joints
Old Jun 17, 2013 | 02:52 PM
BigDaddy0381's Avatar
I had a popping a while back. it was my sway bar bushings were wore out.
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
smok'nZ
Oct 6, 2015 01:14 PM
turbo6c3
Oct 5, 2015 06:11 PM
trevorh1
Sep 27, 2015 08:47 PM
