Planning for transmission failure
Old May 12, 2014 | 05:58 PM
454navyss's Avatar
Default Planning for transmission failure
I'm sure I'm going to beak my 4l60e again, probably not long after I get this build done. That being said, I have been tossing around the idea of putting a th400 in it, it's not a daily driver, set up mostly for drag racing, I've already spent a lot more than I planned on and a th400 would be cheaper than a 4l80e and just as strong if not stronger.
What needs to be done for the swap? Parts, wiring, speedometer, tuning, etc?
I did a search and checked the stickies but didn't really come up with anything useful.
Old May 16, 2014 | 10:14 PM
454navyss's Avatar
Nobody?
Old May 17, 2014 | 07:50 AM
dirt track racer 81's Avatar
I do make the tubular crossmember for the th400, along with the 4l80e. You'll need a converter. Wiring shouldn't need any of that. Tuning wise I'm not sure what you'll need to do, might search on ls1 tech on what guys do on the tuning, I think you set it up thinking its a manual trans?
Old May 17, 2014 | 09:57 AM
Boost-freak's Avatar
i think you need some parts from 4l80e like the rear u-joint and crank spacer and flex plate from B&M
i am not 100% sure about what you need for swap but that is what i remeber
Old May 18, 2014 | 11:23 PM
454navyss's Avatar
I was wondering of your crossmembers would work for a th400 as well, Tyler.
It would make sense to set it up as a manual transmission, and rossler makes a speed sensor for the th350 to work with an LS, wondering if the same sensor would work for a th400.
TCI makes a flexplate that allows the use of any conventional th400 torque converter/stall. I would have to have my driveshaft shortened and buy a 3 speed shifter to replace the 4 speed column shifter.
Old May 20, 2014 | 12:38 PM
James B.'s Avatar
Budget on swapping out the rear end gears too, you're going to need higher gearing with no overdrive.
Old May 20, 2014 | 01:25 PM
Yes I do make a crossmember for the th400
Old May 24, 2014 | 10:25 PM
454navyss's Avatar
I have 3.73s in it now, going to 4.30s and I still have some 3.42s in the attic but I'm not concerned about gas mileage and the truck isn't daily driven
zblee
63
Jun 10, 2023 01:25 PM
Dan Neumann
11
Aug 7, 2022 09:06 AM
JFortner5
Aug 20, 2015 06:13 PM
Ammadien
Jul 22, 2015 08:50 PM
