pinion seal?
Old Dec 30, 2007 | 03:56 PM
MGMC's Avatar
12 Second Club
Default pinion seal?
i got a pinion seal leak. is there any special tools i need to tackle this? i dont think i need to re-shim anything because im not taking that gear out, just the yoke and replacing that seal. i got a parts break down of it and it looks simple, but ive never done gear stuff.
Old Dec 30, 2007 | 04:16 PM
hmatiak's Avatar
You should be able to just pull the drive shaft off, remove the yoke and swap the seal. when you put it back together be sure you dont over tighten the nut on the pinion, that will change the amount of preload that is on the pinion bearings
Old Dec 30, 2007 | 04:24 PM
Wilde Racing's Avatar
How do I change this text
You can do it this way, but the right way would be to replace the crush sleeve and re-set the pinion preload. Of course the carrier must be removed to do this so it makes it a super pain in the ***. but it is up to you, if you don't replace the crush sleeve, be very very very carful not to over tighten the nut.......
Old Dec 30, 2007 | 04:31 PM
MGMC's Avatar
12 Second Club
yeah i dont have the tools nor the experience to do the whole wizbanger. ill go the other route, whats the torque on that nut? does the yoke come right off or do i need a puller?
Old Dec 30, 2007 | 04:48 PM
hmatiak's Avatar
[QUOTE=MGMC;3811909]yeah i dont have the tools nor the experience to do the whole wizbanger. ill go the other route, whats the torque on that nut? does the yoke come right off or do i need a puller?[/QUOTE
The amount of torque is different per application, the yoke just needs to sit back down on the backside of the bearing w/o adding any preload to it. If you over tighten it it will compress the crush sleeve more and put more pressure on the bearings, that could wear them out quicker. The yoke can come right off, but usually a good brass hammer helps it along.
Old Dec 30, 2007 | 05:05 PM
There is no pinion nut torque spec, you tighten it down and crush the sleeve until you obtain the proper rolling toque of the pinion assy... What you want to do is tighten it as tight as possible with-out crushing the sleeve any further. You can do it this way but I would recommend doing it the right way.
Old Dec 30, 2007 | 05:16 PM
hmatiak's Avatar
Wilde is right, if you want to be sure its right, than take the time and do it right the first time. You might consider just keeping an eye on the fluid level and save for some gears and a locker(if you havent done that stuff already) since you will basicly rebuild the rear anyway just for a seal
Old Dec 30, 2007 | 08:57 PM
MGMC's Avatar
12 Second Club
some months back i had 3.73 + eaton posi installed by a local guy here, he screwed up and over torqued a bearing. so in the middle of a road trip, i started hearing the noise. when i got to missouri i took it to a dealership and they redid it for me. i dont have a reciept or anything but is there anyway to see if the work they did is still under warranty online? ill give a local dealership here a call tomorrow for sure.
Old Dec 30, 2007 | 09:03 PM
joshua022's Avatar
just mark the flange nut and the flange with a marker, take it apart swap the seal and then line it back up as good as possible and you shouldn't overtorque the nut.
Thats how we do them at work.
Old Dec 31, 2007 | 08:10 AM
Grumpy5.3's Avatar
what he said, done it a million times. be sure to put some pipe dope on the inside of the splines before you install the yolk on the pinion.
