pick a converter for me
Old May 23, 2008 | 09:45 AM
  #31
BigKID's Avatar
Originally Posted by DanaliHD
ok, thank the lord it is done and it actually does fit. Thanks a billion to Dave at Yank for having the patience to deal with my cocky trans guy and for solving the O-ring issue. Yes it's true, sledgehammers work wonders.
Sounds like the exact same issue I had. Took me three months and two converters to figure out it was the $.20 TCC o-ring on the input shaft.
Old May 25, 2008 | 06:29 PM
  #32
ok 2 things I've notices aside from the stall speed being far, far too high for my taste.
1) the truck surges much worse than before. when i let off the gas and just coast it surges something fierce. When i come to a stop it surges and often stalls. When i switch from reverse to drive or drive to reverse it usually stalls.
2) there is an obvious clunk when i let off the throttle and when i put it in drive. my father in law said it sounds like the driveshaft. Could he have left out a spacer or something?
Truck is still for sale by the way.
Old May 26, 2008 | 10:52 PM
  #33
CHarris's Avatar
You may be reaching the point where you've altered accessory drag enough that it needs some tweaking. On mine, the combination of the light weight convertor (like you just added) and the e-fans caused issues. Certainly your idle airflow tables are skewed... and you're seeing the amplified results now. You've changed how the truck idles and its demand for air. You must adjust.
Can you pm me some info on the vacuum bypass? If it delays boost a little longer I may get one too just to keep out of boost a bit longer. How does it work?
Old May 26, 2008 | 11:32 PM
  #34
i'm hopefully going in for a tune on Thursday. Hopefully the guy can tune my 2bar sd setup. if not, i'm porked cause i don't wanna spend the $650 for HPtuners right now. I don't have any info on the bypass. I called KB and that's what they said i needed.
Old May 27, 2008 | 12:50 AM
  #35
SincalT/A's Avatar
Just something you could check real quick would be battery terminals.I was having some stalling/surging issues on sat. turned out to be corroded&loose.Don't get your hopes up but is worth a look.
Old May 27, 2008 | 06:27 AM
  #36
hmm, i did just move my battery on saturday.
Oobray
Jun 13, 2022 03:38 AM
fastjweb
Aug 15, 2015 10:47 AM
Aboss
Aug 11, 2015 09:05 AM
darnie
Aug 10, 2015 10:25 AM
KyleW707
Jul 29, 2015 08:17 AM
