Two piece drive shaft
Old May 24, 2008 | 01:51 PM
jcb5's Avatar
Default Two piece drive shaft
Does anyone have a picture of a two piece drive shaft setup. I'm thinking of fitting a 2 piece on my SSS and I'd like to see a picture of how they are setup.
Thanks
Ivan
Old May 25, 2008 | 04:22 PM
slamed 07 4dr's Avatar
i have a two peace setup on my crew cab on witch vehicle do u want it for.
Old May 25, 2008 | 05:52 PM
jcb5's Avatar
I have a Siverado 04 SS ,I'd like to see a pic of center bearing and cross member setup, Thanks .
Ivan
Old May 25, 2008 | 06:20 PM
RandomHero's Avatar
look on belltech's website. They have how to instructions on installing carrier bearing kits and will show you the pictures you need.
Old May 26, 2008 | 05:10 PM
hmatiak's Avatar
A great upgrade to the one pc aluminum. Here are a few pics of the cross member i made for my swap. I just bolted it to the bottom of the frame rails, and bolted the bearing to the topside of the square tubing. A big improvement for the vibration issues.
I got a steal of a deal, paid 150 for all of it, but found i couldnt use the ECSB cross member after the fact.
Old May 26, 2008 | 09:27 PM
well im going to the shop this weekend ill take a pic of it and put on so u could see it im in louisiana working and dont have no jack or nothing to get under it
Old May 27, 2008 | 06:31 AM
jcb5's Avatar
Thanks For that,that could be a way for me to go. That ECSB cross member,my truck as a cross member that looks like that ,with a different plate on top that carried the evap canister/filter, it goes across right in front of the fuel tank, Does this sound like it's in about the right place.
That would be great, thanks very much.
Old May 27, 2008 | 04:57 PM
hmatiak's Avatar
Ya, thats the right placement. That is where it should have went, but the rear section of the frame is different for me, so i had to make something else work. Either the gas tank was further forward or just a little larger. Get your drive shafts and see how it lines up, you might get lucky and just need a new plate on top of the existing cross member.
GXPJAY
Feb 13, 2022 08:15 AM
Blue03sss
Mar 7, 2019 05:06 PM
pjb1972
Sep 17, 2015 02:06 PM
Ketis
Jul 23, 2015 12:37 PM
