P1870 after rebuild.. help?
Old Jun 16, 2009 | 08:04 PM
stevenc's Avatar
Default P1870 after rebuild.. help?
So, here is my series of events.
I broke the rear ring gear. I replace that and the related items (pinion gears etc).
I replaced the clutches in my 3-4 9 pack as the steels were in bad shape. the rest of the steels and clutches were in good shape and had good clearences.
I replaced the band.
I then installed the transgo-hd2 kit (most recent edition).
Replaced the seals etc.
Everything is amazing, better then when I had a shop rebuild it....
EXCEPT...
I now throw a p1870 code. Any ideas guys?
Old Jun 18, 2009 | 10:44 AM
stevenc's Avatar
any idears guys?
Old Jun 19, 2009 | 03:20 AM
Parke10's Avatar
just wait a bit,FLT or performabuilt should chime n and be able to help
Old Jun 19, 2009 | 08:39 AM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
P1870 generally happens when the TCC is commanded on and either slips or does not engage. I would verify lockup is happening first, If not here a list of possible causes for no lockup.
1-oring missing from input shaft
2-TCC VALVE missasembled
3-PWM valve assembly missassembled
4-TCC solenoid bad
5-PWM solenoid bad (TG KIT SHOULD HAVE MADE THIS A NILL POINT)
6-Converter clutch issue.
Hope this helps and dont drive it alot till fixed P1870 will cause max line and potential damage possible to hard parts
Old Jun 19, 2009 | 05:22 PM
stevenc's Avatar
4-TCC solenoid bad
AH CRAP!....
I am 90% sure its the orgin missing from the input shaft.
jmix
Jul 10, 2014 05:24 AM
Tkosinski2
Jun 19, 2012 01:32 AM
budhayes3
Jul 9, 2011 11:48 PM
nebnosnevel
Mar 27, 2011 09:35 PM
RTICWOLF
Jul 12, 2005 10:29 AM
