P0757
Old Feb 28, 2009 | 09:21 PM
1955 Chevy's Avatar
Default P0757
I have had this code come on twice now.. I have a 2500 stall... so what I have read the TC should not be the problem.. when code comes on is when coming to a stop then truck doesnt wish to move, maybe is trying to move in 3rd gear??? I can manually put into 2nd gear and it goes fine. If I put into
1st gear it makes noise so I shift out immediately... Is B solenoid going out or is it more serious problem?? If kill the truck & go eat etc & start again all is normal except for check engine light stays on for a while..
Old Mar 1, 2009 | 09:31 AM
FLT's Avatar
FLT
FormerVendor
When this happens are you driving the truck hard? I know your converter stall is not that high but I have seen this code get thrown in a 2400-2600 converter. In most cases with a stall converter the tests in the computer for a PO751 and PO757 should be removed. I do believe the condition you are seeing is a limp mode condition which in this case is 3rd gear starts. I believe some tuning will fix your issue. How long have you had the converter? Vince
Old Mar 1, 2009 | 09:42 AM
00ChevyScott's Avatar
Wearin' da big hat
Ya its in the tune. Disable the tests for that code. It fixed mine.
Old Mar 1, 2009 | 09:59 AM
1955 Chevy's Avatar
thanks for replies...
both times this has happened, I was driving easy.. 1/3 throttle at most before coming to yield or stop... the last time the truck had been sitting for half hour or so since a 5 to 60 mph run..... the first time the throttle had never been over 1/2 the entire day.
Old Mar 1, 2009 | 10:01 AM
Wearin' da big hat
It doesn't matter how you were driving it, its just a code that likes to get thrown on some peoples trucks (including mine) whenever an aftermarket converter is installed. Just disable it asap so you're not stuck driving around in 3rd gear all day.
Old Mar 1, 2009 | 10:02 AM
1955 Chevy's Avatar
Vince, sorry, I bought this pickup some months ago after selling trans am.. had this convertor in it then.. best I can find out the trans & tc were done about 50K ago..
Old Mar 1, 2009 | 10:07 AM
1955 Chevy's Avatar
Scott, thanks... is disabling the "tests" something I could do with some tuning software or does computer need to sent off? I have been thinking about getting some program so I can at least view IATs, better A/F ratio readings, codes etc..
Old Mar 1, 2009 | 10:18 AM
Wearin' da big hat
You can do this with EFILive for sure, and I'm sure it can also be turned off with HPTuners.
Old Mar 1, 2009 | 10:24 AM
1955 Chevy's Avatar
thanks again... sorry for dumb questions.. I am old & slow.. and new to FI... and now in last year or so I have 3... an 07 duramax ec 4wd...for work.. the C3 with radix.. and the wife just bought an 04 PT cruiser turbo... I have lots to learn..
KleenHall
Jul 8, 2011 07:02 AM
RotaryResurrection
Mar 26, 2010 11:24 PM
BlackGMC
Nov 25, 2008 12:59 PM
ap2002
May 7, 2007 05:29 PM
closet red neck
Sep 17, 2006 01:48 PM
