ongoing 4wd-2wd thread and weight loss
#41
Originally Posted by parish8
of course i am going to drop the tcase but it is going to cost money to do. you cant just yank it off and go. the tcase will have to come out later when i have a little more money to throw at the truck.
#42
single digit dreamer
round 2. i am going to paste this in the first post.
tonight i pulled off most of the tortion bar suspension stuff.
20lbs for left tortion
20lbs for right tortion
15lbs for tortion bar cross member
4.5lbs for left key
4.5lbs for right key
64lbs for tortion bar stuff. there are still a couple of cross memeber supports i can take off.
couple of other things i pulled off
4.5lbs for tcase controler
10lbs for sway bar with hardware
3lbs for 2 suspension limiters
add this to the 144lbs above and it is at 144+64+17.5 = 225.5lbs
coil overs will add a few lb's but not much since i still have to take off the stock shocks.
4.5lbs for left key
#43
Originally Posted by dirt_track_racer_81
would need a longer driveshaft and the tailhousing of a 2wd 4l80-e trans wouldnt ya? sorry by some of the posts you made i thought you was going to leave it..had a couple yeager bombs and vodka/red bulls
#44
tranny has to come out and goto finishline for a 2wd output shaft. i want to do a stall at the same time so it is going to cost a few bucks.
#45
what size stall you going for?
#46
i have a 10.5" tripple disk now and it is set up as loose as it can go. i would call it a 2800. next step is a 9.5" multidisk. i would like to see 3500-4000rpm.
#49
Originally Posted by CurtD
I wanted a 9.5" to have a higher stall, Chuck said i would blow through a 9.5...so i got a 10.5 Multi disc.
the problem is i want to be able to race this truck without the nitrous. if i have a brake i will be able to build boost no matter what but how do you prestage, build boost, then roll 1 foot to full stage. thats just not going to work with this tight of a stall. with a looser stall i think i can get a 2step and get it to build boost prestaging and still be able to let the truck roll into the full stage lights. then tbrake, higher 2step rpms, full launch boost should all be able to happen in a fraction of a second.
#50
Unless I've missed it... are you planning on keeping...
Stereo and all associated speakers and harness(s)?
Complete A/C system?
Power Steering? (If you are going to front skinnies)
All insulation inside the truck including padding underneath the carpet?
Power brake booster and all associated antilock harware and harness(s)?
The only thing that would cost you any money as far as these ideas are concerned are a manual brake reservoir and some tubing to fab up some replacement brake lines...
... not sure how streetable you want the truck to be including creature comforts but some ideas anyway unless, like I said, I missed stuff you've already done in other threads...
Bill
Bill
