Official A4 to M6 (T-56) Thread!
Old Aug 30, 2007 | 07:10 PM
  #441
IMD's Avatar
IMD
Banned
i make a sweet remote bleeder. one man operation, dont have to even jack the truck up. PM me for details.
Old Sep 5, 2007 | 02:14 AM
  #442
IslandTahoe's Avatar
Ok just received my NEW GM part #15027983 which is the clutch pedal assembly. This came as the pedal only. No hydraulic master cylinder or lines attached. Is this correct? I was under the impression that this should be the whole hydraulic system complete to the quick connect fitting.
If the master cylinder and lines are a separate part, does someone have a part# available?
Thanks
Old Sep 5, 2007 | 04:29 AM
  #443
04GIBBS's Avatar
If you look at my previous postings you will find that info available. But it is all seperate
Old Sep 5, 2007 | 07:22 AM
  #444
Lord Aries's Avatar
Thanks
Here are some part numbers I have gathered... Prices are including shipping from GMPartsdirect.com and they are a lot chear then the dealer!!!
- Clutch Pedal Assembly #15027983 $66.00
- Clutch Pedal Bracket #15713209 $4.82
- Clutch Switch #15027967 $30.89
I found two of the following for the trucks, I think the first one is the one you need...???
- Clutch Master Cylinder/Hydraulic Line #2423561 $108.26
- Clutch Master Cylinder/Hydraulic Line #15727261 $153.60
And to finish it off, a nice new trim piece for the Steering Colum with out the hole for the Gear Selctor...
- Steering Column Trim/Cover #26072994 $0.00 / $25.77
Old Sep 5, 2007 | 11:42 AM
  #445
Got the pedal assm, got the trim piece and got the clutch switch.....just missing the hyd stuff.
As for the pedal bracket, although I haven't gone under the dash to test fit the pieces, at first glance it doesn't seem to be the right part. Will comment more later.
Will research the hyd line part #'s.
Thanks all for the help.
Old Sep 5, 2007 | 11:50 AM
  #446
Is there a digit missing from the first part number? Doesn't register any finds and looks a digit short.
Old Sep 5, 2007 | 12:38 PM
  #447
try Clutch Master/Hydraulic Line #24235619
got it off page 38
Old Sep 5, 2007 | 12:58 PM
  #448
ahhh soooo....... missed it
thanks for the help
Old Sep 5, 2007 | 11:15 PM
  #449
IMD's Avatar
IMD
Banned
when you buy the clutch master...it comes with switch. you wasted $30. also, do yourself a favor, if you dont already have a new slave cylinder, buy the one for the Z06. i learned the hard way, used a used pre 99 f-body slave, it failed in three weeks. i slid the Z06 unit in, and the truck shifts really really nice. when you first bleed a brand new slave, bleed the system untill you get a good flow of fresh fluid coming out of the bleeder. then, without opening the bleeder, pump the pedal over and over and over again, this is the only way you will ever get a good pedal. when you just bleed it, the fluid goes right through the slave withough first filling it up....and it takes a ton of fluid to fill it up.
Old Sep 5, 2007 | 11:18 PM
  #450
IMD's Avatar
IMD
Banned
this is the number for the clutch master i used personally.
Clutch Pedal..............15027983.......57.45
Brake Pedal Pad..........15706041........3.65
X-member.................15748078......127.95
Z06 Clutch/flywheel....12570806......475.86
Roller Pilot Bearing.......14061685......16.03
Clutch Master/Line......15033984.....129.02
